I've just run some 2 core 10mm Swa to my garage but not yet connected at either end. I've only used Swa in factory installs before and never needed to bury any underground. I planned on using the steel wire armouring as the earth as I have done previously and I know Swa is ok to bury but a sparky at work said it's not recommended and I should have used 3 core as the armouring can rot eventually. I cant find anything in the regs that states I cant use the armouring as the earth when it's buried underground.
