Hi I was thinking that if you can ,like you say , screw and unscrew that pipe bracket on nearest side to you only ( so bracket stays on wall ... just unscrew the pipe ,manipulate the whole pipe , bends aswell , so it comes away from stop end outlet . And bring the whole lot inside to where you are unscrewing from , clear pipe out and replace back .. manipulate back into position and re screw . It’s really as easy as that , as the whole pipe by the look of it is only half a metre long and won’t be hard to manoeuvre . If anything breaks the pieces that do can easily be replaced .. I’d think about that hole in your soffits aswell block to stop creatures entering
