Thanks, I understand that. I want the whole lot to be where it is now, because moving it would mean running a cable past the window in the left of the picture and, it goes all the way to the eaves so a cable would be unsightly.It is. You can then locate the PIR where it will actually work properly, which is almost always NOT where the light is.
Something (new P.I.R.) will need to go over the hole to hide it and the above it, between the P.I.R. and the eaves. The door is on the right so, there's only the width of the pillar to mount both.
