If its a heat only it won't have isolators on the flow and return and no internal expansion vessel or auto air vent to worry about. You will get a bit of water when you crack the joints and it may well be mucky so protect carpets etc.
I would close both the trv and lockshield. Release pressure in the rad via the bleed screw. Undo the joint between trv and rad with a drip tray underneath. Have a compression stopend (just the male part) ready and use it to seal the rad. Direct trv over a bucket and open it. This will depressurise system and water should soon stop. Remove and rotate trv. Put it all back together open valves and repressurise.
