- Joined
- 25 Jul 2022
- Messages
- 18,406
- Reaction score
- 1,567
- Country
If you have dismissed all the other possibilities and confirmed it is suspension action (movement of wheel up and down), then it limits the possibilities to strut, spring, top mount, drop link arm, anti roll bar or wishbone.What I've personally done is to listen to it from the inside, while driving the car. The sound, audibly comes from the suspension, when going over uneven surfaces, as I mentioned in the original post. But, as also mentioned, many of the stuff around it have already been replaced.
I would remove the anti roll bar drop link and see if the noise continues, to confirm or elimanate that. Then move onto the other items, and as others have suggetsed the shock moving sounds likely.
Forget what parts have been changed, faulty parts, or even slightly loose fitting can happen
