Going back to my question, can I use a standard oil fired combi boiler or is it best to use a system boiler with zone valves to control the swimming pool seperately.
Does the heating have to be on all the time to heat a swimming pool or does it only need to be on during its use.
What are the important factors I need to know about heating the pool, etc..
Does anyone know of any websites I can look at regarding design,etc..
Do you have to have a seperate heat exchanger or can you heat the pool directly from a oil fired system boiler.
If a normal boiler is used, what does it connect into....
