I need to replace an old cooker. There is a hard wired switch behind the cooker and the cable seems to be inside a metal conduit buried within the plaster. I could not pull the cooker to take a proper picture since it is a gas appliance. There is an Unswitched FCU and a 2 gang Cooker Switch & Socket with neon at around 400mm above the top of the hobs (above and behind the cooker). There are also a gas pipe, central heating, hot water an other copper pipes that run alongside and behind the appliance.
The new cooker will be gas and will also have an electric cable flex that will run behind it and up to the switch. Currently on a budget, I would like to leave the hard wired switch where it is but put a 600mm x 600mm splashback supported with brackets and enough gap between it and the wall to allow the 13Amp plug to be connected to the switch. Would that be a viable solution?
Another point: There is an old extractor fan with a pull cord located well above the cooker. Could that now be a problem? I may not use it at all but is it a requirement that kitchens do have an extractor fan even though there are windows in the same room? Just want to be sure.
I have included two pictures.
Thank you.
View media item 73602 View media item 73603
Thank you.
