I am installing two ventilation fans with timers in a RCD protected lighting circuit (5A MCB) covering 3 rooms (bathroom, toilet, utility room).
The fans are an inline Manrose MF100T for the refitted bathroom; and a wall mounted Manrose XF100T in the new downstairs toilet. A sparky told me I needed 3 pole isolating switches for each fan, but the manufacturers instructions say switch fuse units are also needed.
I didn’t see how one fuse unit could cover the constant and switched live feeds, but found circuit diagrams in the diynot.com wiki section under “fuse for ventilation fan with timer”. The best circuit seems to be that at the end of article, using a two pole switch fuse and a double pole switch. However, it seems to be dated 24/04/07: is it still compliant with the 2018 regs?
For the online fan, presumably I can mount the switch fuse beside the fan in the loft. The wall mounted fan in the downstairs toilet is mounted at ceiling level above the WC - with the small wash basin at the other end of the room (1.6 metres away). Can I mount the switch fuse above the WC - alongside the fan? It would involve considerable wiring and drilling to mount it outside the room.
I would be grateful for some advice
