So, which way round would you do it ?
You have a request to be able to switch off everything but a dedicated socket circuit, some lights, and the heating - partly as a "can't leave something on" measure, mostly as a "leave as little as possible powered up when the old, listed, and containing a lot of wood building is empty" measure.
So, do you route each circuit individually via a contactor ? Pros - the contactor only has to be rated for the highest RCBO rating; it's flexible as to which circuits are switched. Cons - you quickly start needing a lot of poles (multiple contactors ?). That's the way the night storage was switched in the office I used to work in - but then it was only one or two circuits to be switched.
Or split the live bar and switch the feed to the RCBOs ? Pros - only need one contactor pole (or 2 if you switch the neutral as well), wiring is simpler as you don't need to split the L for each circuit off via the contactor. Cons - need a higher rating for the contactor; less flexible in allocation of circuits.
Neither option seems to have an overwhelming "that's the right way to do it" argument
For background ... at the moment there's only 7 circuits (3x lights, 2x sockets, 1x heating, 1x organ blower). But I know they are looking to significantly increase this - especially if they get funding for some alterations (including adding a kitchen).
