SwitchFuse/DNO Connections
I was assuming the OP was just brining in the tails through stuffing glands, else brass glands will be OK but expensive. Don't use a steel locknut directly onto the switchfuse case; use a brass one or banjo in between.
Thanks guys. Reason being the hager switchfuse I have has one 30mm knockout top and bottom. And due to space constraints the swa must come in the bottom.
If its a suitable option then my preferred way would simply be to cut 3 smaller gland holes close to each other and put a slit between them.
You only need 32mm, not 38 - wouldn't take long with a decent rat-tail file.
