My central heating system is based on a Worcester Greenstar system boiler. The system has been losing pressure slowly for the past year or so, needing a top up through the filling valve every fortnight or so. In the past week, the pressure loss has become much more severe, with the pressure dropping from 1.5 bar to the lowest point on the gauge (red zone) in about 2 to 3 hours.
There doesn't appear to be any leaks around radiators or in the garage where the boiler is located. I guess the leak would be quite obvious since I am topping it up quite regularly now.
I checked almost all radiators for air and there were two that needed bleeding but nothing unusual and the situation still persists after bleeding.
I am also noticing that the radiators are not outputting the same heat. A couple are almost too hot to touch, others luke warm and others almost cold. Also one or two radiators are making a gurgling sound occassionally. These have all been checked for trapped air. I understand the difference in temperature means that the system needs balancing, but not sure if this is a separate problem from the pressure drop or a related one.
Any ideas what the issue could be? Could it be the built-in pump that is faulty and not developing enough pressure for the circulation? Could it be a defective expansion vessel?
Thanks.
Thanks.
