- Joined
- 14 Oct 2024
- Messages
- 4
- Reaction score
- 0
- Country
Due to some recent building works the hot water cylinder that was in my. loft was relocated and some legs have been run for 3 more radiators which have yet to be fitted.
Hot water has been fine since the relocation of the cylinder around 4 weeks ago. This weeknd I put the heating on, all was fine but next morning when the hot water cycle ran (before the heating comes on).
The hot water and heating is supplied via an air source heat pump, the unit showed a low pressure error so I filled the system to about 1.7bar when heating was on and bled the radiators. I manually put water cycle on and cylinder had hot water.
Next morning after heating had been on the night before same problem. It seems that when I fill the system within about 30 mins pressure drops to 1 bar or less, however all rads are nice and hot.
Seems the pump itself is fine but something within the system needs adjusting. I should also add that a new expansion vessel was fitted to the cylinder when it was relocated.
Any ideas? Thanks.
Any ideas? Thanks.
