I need to supply power to a barn that we have just had built - when it was built the builder installed a service duct between the house and the barn. The cable run will need to be about 50 metres, can you used twin and earth for outside runs in conduit / ducting?
The barn itself has already been wired and the CU has been installed. I reckon that i will need 16mm2 cable to supply it - a 32A ring and lighting.
Connecting up at the house end shouldn't be too much of a problem - I have had the supply upgraded from 60A to 100A - this is happening on Tuesday and the meter is going to be moved from inside the house to a box on the outside - my plan is to put a 100A main switch in this box and then have a 60A fused switch for the house and a 40A one for the barn
Any thoughts / advice would be great
