I have a table lamp that is two core. It is quite complex and has various light elements (six in total) that plug into the base of the lamp with continental 2 pin adaptors. The lamp dates from the 1960's and it looks like the fittings for both the male socket and lamps cannot simply be replaced by earthed versions.
Question is if I run 3 core to the main body and earth it but only have two core on the arms which will be not earthed in certain positions will this fail a pat test ( I presume yes).
If I wire in an inline rcd plug would it pass a pat test?
Cheers Frank[/img]
Cheers Frank[/img]
