That would definitely improve standards, but at what cost? .... The HSE is encouraging a pragmatic approach, reducing risks in a 'Reasonably Practicable' way. .... Is the extra cost justifiable to catch 99.99% of failures, over 99.9%?
We've been through essentially the same discussion (including that about 'requirements' and regulation), repeatedly and at length, in relation to EICRs and, indeed, even more generally in relation to "Part P" and BS7671.
For a start, risk-based cost-effectiveness assessments in relation to matters of safety are not necessarily all that 'rational' if viewed dispassionately. Even in the case of 'obvious' things like RCD protection, I've often been known to suggest that the billions spent on such devices could have 'saved far more lives' if diverted to some totally different safety-related issue.
One important issue (with both EICRs and PA tests) is that there are costs on both sides of the fence. Those 'testers' who, either to protect their backsides or (particularly with EICRs) to 'generate work', 'err' very much on the side of 'failing' things can result in considerable ('unnecessary') expenditure on the part of the owners of the equipment/installation.
However, I think the bottom line is that if we have decided that we want EICRs and PA testing etc., then it needs (
in general, not just in situations like yours) to be 'fit for purpose' - which, to my mind, probably necessitates far more regulation than currently exists.
I would imagine that, in the PA testing world in general, those figures are way too optimistic!
In my case, do we employ our two electrical engineers (on academic salaries), full time to maintain and inspect our 15'000 appliances, or is the workload shared between a team of technicians and apprentices?
You appear to be talking about the very 'highest end' of the spectrum of PA testing in general in the real world. If you ask Mr Google "how do you become a PAT tester?" (the redundant/repetitive "T" considerably increases the number of hits
), one gets literally thousands of hits, many of which say things along the lines of this one ...
I have no previous electrical knowledge; will I be OK to attend a PAT course?
You do not need to have any previous electrical experience to attend our one day PAT Competent Person course. We are confident we can train most people and we deliberately keep our class sizes small to ensure that no one gets left behind. If you would like to prepare for the course we would advise reading our training manual beforehand. You can access the training manual from your course account.
... hence my views about the need for sensible "requirements" and regulation.
With health and safety, there is always a heirarchy leading up the management levels and including the HSE. As I have said before, a feedback loop is essential for RA's etc.
As I implied above, there is often no real 'heirarchy' - just an individual (whose 'training' in matters electrical may only have taken one day) and the HSE itself.
If the current PAT system was inadequate, too many failures would show up and the system would have to change.
As with EICRs, in the absence of regulation and audit, we really can't have a clue as to how many 'failures' there might be.
The HSE guidance states there is a legal duty on suppliers and manufacturers to supply safe equipment. ... If PAT was to check that equipment was manufactured correctly, that would require a whole new skillset and would duplicate the efforts of other agencies. .... As in the OP's case, the appliance came from 'a well known large retailer'
Hmmm. In the eyes of those commissioning PA tests (and quite probably the eyes of HSE) 'safety is safety', and if something is unsafe, they don't really care whether that is due to a design/manufacturing fault or to a deterioration or misuse whilst in service, do they?
As in the OP's case, the appliance came from 'a well known large retailer' - although items do slip through the net, the 'Swiss cheese' model of safety would mean 'dangerous' items may be caught at many stages. .... Those that do make it through and are not eventually recalled are (hopefully) so rare, that we get back to, is finding them 'reasonably practicable'.
I'm somewhat confused. Yous seem to be advocating and agreeing with a very sensible and reasonable (essentially 'common sense') risk-assessment-based approach. However, in relation to the OP's lamp, you seem to be agreeing with him that (despite the fact that it is brand new from "a well-known large retailer", and hence ''should be safe') it should fail a PA test, not because it 'may' be an unearthed Class I item but, rather, because it's (insulated and sheathed) power cable does not have the correct insulation colours or a BS marking (and "perceived as poor quality", whatever that means). Does that really mean that your 'risk assessment' leads you to believe that either of those 'technicalities' represents an appreciable risk to users??
Kind Regards, John
