So considering same difference between 2A and 6A then if we draw 39A through a 13A plug you feel the fuse should not blow!
In the real world, a 13A socket on a standard ring circuit drawing 39A is unlikely to ever blow a 30A BS3036 fuse, and would take about 16 hours to operate a BSEN60898 MCB
But there is a 13A fuse in the plug! To draw 39A from a 13A socket protected only by the 30/32A protective device one would need to by pass the 13A fuse in the plug which is a whole different ball game.
But by exactly the same token, you are limited to how much power you can draw from a B22 lamp holder, by not being able to purchase a lamp which will draw more than 2A.
Of course the lamp holder could be abused by someone using a non standard lamp, but you could abuse a 13A socket with one of those unfused multi socket adaptor jobbies.
