Ok - I have just refurbished my fathers old table saw, old but barely used. I found it as a complete top with motor and saw attached, and the stand and fence rails as a pile of parts.
I would guess it was a 'cheap' diy type one - not a woodworking workshop model.
It is a Power Performance 1800W ( FMTC 1800ST )
View media item 104554
I have removed the guards, riving knife and blade, cleaned out all the old sawdust and put it back together with a brand new blade.
I have rebuilt the stand and put it all back together.
It took a fair while to figure out how to attach the fence rails and how they worked.
Below is rebuilt - less the fence rails being attached and less the blade being swapped for a new one.
View media item 104555
I have yet to figure out how the switch was attached.
Not used it to cut anything yet, but it has been powered up, starts up instantly and seems to be braked as stops in a few seconds.
I have some questions though - being new to table saws and their use.
1. The riving knife is currently set very high like in the picture - and is set about 10mm away from the blade. What is it's ideal setting? above - level with the top - below ?
2. I want to resize some 6 x 2 boards - to make 3 x 1 (or nearest allowing for cutting waste)
Guessing here that removing the guard and doing this as one pass then flipping over the board and doing it again from the other side is a no no as this machine is not big or heavy enough and has no appropriate fences and guides? There is an extension piece that fits on the wing nuts to the left in the pic - adding 3 feet of extra bed length.
3. As above - can I safely do the above but by ripping the boards down the middle first - then cutting the resulting 3 x 2 into 3 x 1?
The label appears to say 4" depth is ok - but what should I be looking out for, or doing, to cut timber like this as it will be on its narrow edge and close to the blade.
I found the original push stick - 8 inches of plastic and binned it - and will be making one around 18" long instead!
I know about kickback - and staying out of the way of behind the timber where possible.
Yes - the floor is now clear of crap too.....
Any advice welcome.
Many Thanks
Gerry
Any advice welcome.
Many Thanks
Gerry
