Table saw
11 Feb 2007
Essex
Hi Guys, I've been looking at the B&Q Mac Allister table saw (254mm) which is now reduced to £103.99. I only require this for moderate diy use, I would appreciate any comments or reviews on this?
Many thanks,
Barry :)
The £100 would be better spent on a decent circular saw , it will out last any cheap table saw.
Just bought the above table saw, again for light domestic use only.
The saw itself seems rugged enough for the use I will give it, and everything seems pretty sturdy. The table-top itself is larger than a lot of other low-end saws, even without the extending sides, and that is the main reason I bought it ... I didn't much fancy trying to improvise extensions with chairs and so on.
BUT ... The fence that comes with the saw doesn't lock down parallel to the blade (may just be mine), which makes it pretty useless for ripping. It's a couple of mil out. I could always use a clamp on the far end to bring it parallel, but that kind of defeats the object of having the rip fence.
Also, the mitre gauge feels flimsy and cheap. It is sloppy in the mitre slot, moving both up and down and side to side, again making it pretty much useless. It rides in a shallow "T" slot, even making it difficult to swap it for a better one.
I am going to swap the fence for a "straight edge clamp" (with an adjustment made to it), and improvise another method of cross-cutting, rather than using the mitre gauge.
With the wonderful benefit of hindsight, it may well have been a better idea to hang on a month or two and save up for a Ryobi or similar one around the 200 quid mark.
nearly all table saws under 350 quid are majorly let down by useless fence. a good second hand one is often a better bet as they have so little to go wrong. a 200 quid or under table saw will make a worse job of straight cuts than a decent circular saw and clamped straight edge
