Single red and bare earth in grey sheathing is pretty rare I would have thought, i wonder if the 2 black cores are snipped off
So would I. In fact, I personally have never seen single+earth cables, other than in photos!Single red and bare earth in grey sheathing is pretty rare I would have thought,...
That's possible, but it wouldn't alter what I said - that the black conductor at the light must come from somewhere and (given the light works) must be connected to something 'useful' (probably a neutral feed, and certainly not a black conductor that has been snipped off at the switch!) at that somewhere - presumably a JB which, one would imagine, would also have the two conductors from the switch and also a L+N feed.i wonder if the 2 black cores are snipped off
It could be. However, assuming what we have been giold is true, that still would does not alter what I've been saying ...It could also be singles to the light.
As I said, I've personal never seen it used, although I've 'always' been aware that it is sometimes used.I've certainly seen at least one property wired with 'red and earth' cable looped from switch to switch, and another run of same from each switch to the light(s). A double insulated single-core neutral looped from light to light, completing the circuit. ... It confused me when I first met it, but seemed to be actually quite a good design.
True. One could have power feed, switch and light all in series (in a 'ring') with separate single conductors between them (in a 'ring') - just as with an experiment on a classroom bench. However, with AC that is just about the 'worst possible scenario' in terms of EMC radiation, so I would say 'not recommended'!It’s not unusual for the signal neutral to leave the CU and go direct to light points. And the single live to go wherever necessary.
Exactly
It was most useful for 2 way switching.
Then you only needed twin between the switches
In the mid-60s (or earlier) you were presumably lucky to have single + earth (rather than 'single without earth') cables in lighting circuits!This place had lots of single + earth used in it, in what I would guess was the mid 60's - all long since replaced.
Yeah mid 60s didn’t have an Earth. Just double insulated singles.
An expert could accurately date the op’s install with the green cpc sleeving.
I’m going for the early 70s
