Tap tails too short
undo the nut after the isolation valves and fit a couple of short bits of copper. you'll still have to go to screwfix and get some 15 mm olives and maybe new nuts to save you faffing about to reuse those nuts
If, as you suspect, the new tap is continental, you MAY find the flexis have 10mm (or even 3/8BSP) fittings on the "non-tap" end! If that is the case, you will need 15mm to 10mm converters. I brought a tap back from Spain to find the same thing, but fortunately, before I started I realised the pipes were continental.
