Empty the recycle bin.
Have you got Ccleaner installed? If not:
Download and install
Ccleaner
When installing, watch out for the tick box that will install the Yahoo Toolbar if left ticked
Once installed, click Check For Updates (bottom right of the screen)
Ccleaner. Initial Setup and Operation.
After initial setup, all settings will be saved and only the
Instructions In Bold Underline need be
carried out to run Ccleaner on a regular basis
Options ->
Cookies
Transfer all the cookies that you recognise and use to the righthand column. (This only needs to be done
once OR prior to cleaning when you have visited new sites that may have lodged cookies for sign-in
purposes).
Options ->
Settings
Tick -> Auto check for updates
Dot -> Normal File Deletion ( You can change this if you want to over write the deleted files for securer
deletion)
Options ->
Advanced
Tick -> Only delete files in Temp. . . older that 48 hours.
Tick -> Show promt to backup.
Untick -> All other Options.
Tools ->
Uninstaller
Handy for uninstalling and also if you have uninstalled using Add/Remove but the name remains in the list, click it in this list and click Delete Entry.
Tools ->
Startup
Saves going into Start -> Run -> msconfig to disable programs from running at Startup and you can remove items from the startup list.
Cleaner ->
Windows Tab
Tick IE to put a tick in all, then Untick Autocomplete form history
Tick Win Explorer to put a tick in all.
Tick System to put a tick in all, then Untick Clipboard, Start Menu Shortcuts & Desktop
Shortcuts.
Leave Advanced unticked.
Cleaner ->
Application Tab
Tick All Boxes except Saved Form Information if there is a non-IE browser section.
Click Registry, Tick Registry Integrity to put a tick in all boxes in the list.
Operation
With all browsers shut down click Cleaner then Analyze.
When complete, click Run Cleaner, the Are You Sure screen will popup, click OK
Click Registry, then Scan For Issues
When complete, click Fix Selected Issues.
The offer to Backup will show, click Yes.
It will offer to save in My Documents, click Save.
Then click Fix All Selected Issues, OK.
Then Close.
Did you purge your system restore points? If not:
In Vista:
Follow
these instructions.
Then set a new restore point by following
these instructions
Then run a QUICK SCAN with MBAM not a full scan.
dave
