Using Task manager to stop a program running will NOT stop it from starting when you next boot up.
A simple way to control what starts when you boot up is to download and install Ccleaner
When installing be careful because it tries to install Yahoo toolbar, by default, the install box is ticked, just untick it and procede.
When open, go to Tools -> Startup and look at all that is in the list.
Your security programs MUST be left on but most others can be disabled. Any that you do not know about, just check them out here:
http://www.sysinfo.org/startuplist.php
Type the item in the search box and then decide if you need it running as soon as you boot up.
dave
you can control service startup from vista task manager.
Thanks for that, Eddie.
No mention of which OS by the OP.
I only have XP![]()
dave
To control which programs automatically start up, you could try the System Configuration Utility embedded in Windows:
Start > Run, and in the ‘open’ field, type: msconfig and hit OK. Then select the Startup tab. From here you simply tick or untick which programs you want to auto start on boot up.
You will need to reboot if any changes are made. Obviously you should have some understanding of what is listed, so as to avoid deselecting a critical program.
