I am in the process of fitting a new bath thermostatically controlled mixer which is armitage shanks.
I have been advised to take a dedicated hot supply directly from the hot water cylinder. The thought of drilling into the cylinder makes me a bit nervous. I was going to tee off the pipe coming out of the cylinder top but have been advised I should fit a flange.
I have looked on the internet at Essex, Sussex and more recently the techflange.
The Techflange sounds the simplist of the 3 but I cant get my head round how do you get at it to seal it from the inside of the cylinder. The Techflange comes with a cutter.. Does anyone have any experience of this flange or can you explain in simple terms how do you get it to seal when you cant get at the inside.. probably a really naff question but anyway a bit of advise would be appreciated.
