B
breezer
biblio said:lightening? surely there is no real risk from a strike if you do not have a proper master socket!
you do not need a direct hit, you can also get induced voltages, which can be just as bad
well the master and extention sockets are basically the same designbiblio said:plugwash: thanks for the useful images, so master sockets are physically different. (If you are not supposed to connect to the back of non-NTE5 master, why are there connectors?)
biblio said:raychem: I do not have a master socket because the drop comes in to the roof. Junction boxes are used already to suply two separate lines (only two cores are needeed for each line).
ok so we have two phone lines entering each with a pair of wiresbiblio said:Thanks, yes I always make a layout sketch before undoing anything and keep them all!
There are two different telephone numbers. The drop has 4 conducting cores; plain colours of black, green, orange and white. These go to a 4-way terminal block (BT52A).
with you so farbiblio said:Here the 4-core meets a 6-core (internal cable with prettier colours) Black meets, orange (flecked with white). Green meets, white (flecked with orange). Orange meets, blue (flecked with white). White meets, white (flecked with blue). Straight connections, machine screws, clock-wise loop under pan head, plenty slack in wire leading to screw so as not to copy violin tuner and snap wire at neck.
at least one of Bi and Bii must be a master (open them up and check)biblio said:Line B has two extensions supplied from only two original cores, orange and white. Each one of this pair has two similar cores pairs connected together under a screw head. One for each extension. There are now four spare pairs (from the two 6-core internal cables for Bi and Bii). These are screwed down together in four respective pairs, using little linking double-ended metal y's, but un-extended. These two internal cables are eventually connected to two ordinary sockets Bi, Bii (as at A).
