pigeons seem to like it as well
It is an "digital TV aerial " if it receives DTV.
there isn't any analogue Tv in the UK, not since 2012.
So it's more superfluous to call it "digital" than being untrue
Labgear refer to it as a"digital aerial" in the instruction manual. Screwfix are just relaying that information.
To say they are "liars" is preposterous .
Labgear ARE lying or perhaps mis-informed. But for an aerial manufacturer being mis-informed is preposterous. So they must be lying deliberately.
I was quite happy to say no more until I was insulted in post 21.
To say they are "liars" is propostreous .
Once again Winston, you contribute to the forum for no other reason other than to correct terminology or take the higher ground.
Do one.
Surely the reason ordinary people use the wrong term is because retailers and manufacturers used it first, probably as a means of increasing sales when none were required. You only have to look at the packaging on some manufacturers boxes to realise that.
Winston.... If that post 21 made you feel insulted then your sensitivity to insults level is set far to high.
There was a difference between aerials intended to receive the new digitised TV transmissions ( wide band ) and the existing aerials ( mostly narow band ) that were receiving the existing transmissions for analogue TV.
Due to the channels allocated to the new digitised TV transmissions some aerials had to be changed to wide band to receive digitised TV transmissions as well as the existing channels during the change over process.
