A copper pipe cutter - the sort with the little scoring wheel and a knob to turn to adjust for size is fantastic to use for terminating SWA. Use it first to score the steel armour, then move it along a bit to cut around the black outer cover.
the secret is to disturb the steel spiral as little as possible -DAMHIK
Where's a good place to find a multipack of PVC 3mm sleeving ? The usual merchants only sell each individual colour in 100metre packs and I only need enough to cover the tails of the SWA cable at the consumer end. I would rather sleeve the grey, brown and black with the correct green/yellow, brown, blue sleeves as appropriate. Alternatively, it'll have to be eBay.
