It's a better placeWell you do live in the past woody.
Presuming the party wall 1 brick thick a cavity wall is going to protrude into the room. Either design the different wall depth into the kitchen, maybe fit a deep worktop and cut to 600 where required, or batten the wall off.
Any views on how much a roof will overhang on the side and is there a trick to make the roof flush with the wall?
PMSL are you living in 1987?
Depends on design/orientation i.e. gable wall, hip roof etc. An average soffit over hang (200mm) plus gutter (125mmish) amounts to over 300mm. A cut brick gable could impart as little as say 40mm overhang.Any views on how much a roof will overhang on the side and is there a trick to make the roof flush with the wall?
And a coping presumably?A flush side needs a parapet
Or a cappingAnd a coping presumably?
remember how I said the neighbour's house is offset to the front? the gutter serving the corner bit of MY roof is "overhanging" the neighbour's boundary, just like the gutter serving HER part of the roof at the front of the house is above my boundary. say I got "permission" from the neighbour to build, could the existing gutter, put there by the original builder (council), be used as a precedent? I'm technically "breaking the rules" as we speak, and so is the neighbour, but that's how these houses were originally built.
What you should be doing is determining what you actually want and then designing how to achieve it.based on this, I will probably end up going with the following:
