I’ve a problem with my mains pressure hot water tank not heating. I’m suspecting it’s the 2 port zone valve actuator (Siemens CZV222). Can anybody help me test this theory?
The system boiler works fine & any call for central heating fires it up.
The Water tank works when I switch on the aux heating element, it’s just that the boiler doesn’t fire up when I switch the water on at the controller. Normally we leave the water switched on all the time since the heat loss in the pressurised tank is so small.
If I switch on the water at the HW/CH controlle & slide the lever on the valve actuator from auto to manual, the boiler briefly fires up, but almost immediately goes off again. I’m assuming that there is some gubbins in the zone valve actuator that tells the HW/CH controller that it’s opened OK & maybe this is knackered? It’s either than or my controller is buggered. Any suggestions?
