Some people may have misunderstood my original post because of the pics attached to it. The pipe capping i refer to is in the kitchen. It was just a spare bit of pipe going past the cooker to a water heater which has also been removed. So i just wanted to make it clear that i have NOT capped the gas meter or interfered with any pipework around the meter icon_eek.gif .
You have missed the point entirely!
By interfering with the gas supply inside your property you have made more than a few grave errors, as pointed out by other posts.(i wont bore people with quotes of those!)
When an engineer arrives on site there are about 30/40 things that they are visually looking for before they even open their tool box!! You are getting that response but within a prolonged enviroment.
We are highly trained but i gaurantee that most people including myself would not be able to list every single regulation off the top of the head within 3 minutes, myself included.
We are taught and trained to what is right, and pound to pinch, when something is wrong we spot it on 9.9 times out of 10. We don't need to tell you when something is good or well fitted. Our job is to save lives and ensure that they continue to be safe for the future.
You may find it strange that we don't congratulate you on the fact that you have managed to solder on a stop end all by yourself aawww bless!! If you are so pround of it put a photo up!!
None of us are impressed because you have failed to carry out any safety checks whatsoever!! I mean FFS you still aren't sure whether its leaking or not!!??
When carrying out work on a gas supply there are a minimum of 12 phsical tests that you should be doing before we even get onto visuals!!!
Would you mind telling me which of these you did zemphis??
You are an arrogant DIYer with little regard to your own and other peoples safety. At least have the decency to put up your address so that the neighbours can be warned.!!
