texacom veritas 8
In program mode. I can see where to set a new engineer code from default 1234, but can't see how to set own user code from 4321.
Is it the "glasses issue again?"
Or is it the manual again.
Changing the Engineers Code '60
Each user has a programmable 4 digit Personal
Identification Number (PIN) which the user enters in order
to operate the alarm system.
Every user has the ability to change their own 4 digit
Access code, as follows:
From the Programming Menu, enter '60
So the user code is the engineers code and vis versa
You change the user code from the user manual - it's not in the engineer manual.
Struggling for some reason. i appear to have set the 1234 code to my own code, but can't seem to change the user 4321 code. just get error tone when i try
So can enter program mode ok with new code, but to set alarm i need the 4321 still
Reset to factory now it is the other way around. Is the issue that i am trying the same code for both and you are not able to have the same code for engineer and user?
EDIT
Must be as i can use another. Makes sense i guess .
