I already have a Texecom 48 panel setup and working and am about to get and install my smoke detection system. I have searched the forum and the results dont quite match my questions.
1. Would you install a dedicated mains powered smoke alarm (3 smoke 1 heat) that links through a relay to a zone programmed as fire.
2. Install 3 AGB-0001 and 1 AGB-0003 for the kitchen into zones on an expander. ( does each detector give off a sound like the mains ones or is it only the panel that make the sound)?
3. What are the advantage disadvantage doing it either way?
4. If it was your house what would you or have you done?
Thanks as always
Thanks as always
