texecom internal sounder
The sounder just connects to the bell terminals at the panel , the red wire goes to A ( 12v perm) and the black wire goes to B ( sw-ve)
the two wires coming off the sounder - do they just get taped to the 6 core cable or shall i use a connecting block.
also the sounder i have brought has no wall mounting - should this be put inside another more decorative box? if so where can i obtain one of these from?
thanks
Usually the front comes off to reveal a back plate , this then is screwed to the wall , then the front attached.Yes you can use a terminal block if you wish.
