Texecom Premier 24 ' Activate Device '
I can see 3 sets of wires to the network terminals.
can you do a confirmed devices in eng utils.
there is nothing fixed to the comports, but that along with confirmed devices should show what is available.
not used many 8XE's in my time but recall that they didnt always show up as an expander address 1, zones 9-16
So i would look at udl digi options, comport setup
nothing connected just to check programming
Hi
Taking your advice i looked at Digi options and it said 'enabled' even though a device isn't connected. I disabled the option and now all is back to normal and the Konnected is set up and working.
Thank you very much for the help.
They did some radio plus network expanders towards the end of the radio plus range ....as said it’s got 3 network connections ....does it have 3 keypads ?
Well need to look for programming then.
Com port setup, digi options to which you refer is for communication module not say radio plus reciever
Pictures of units near the panel
Hi, Not sure if you picked up my earlier post above, all sorted now.
Thank you
So you disabled the. Comport? Just in digi options disabling enabled shouldn't have made a difference
Yes disabled the comport and it seemed to sort it, unless it was a coincidence?
FYI, I got a response from Texecom support who suggested rebooting the alarm to sort the 'Activate Device' message
