Its not arming then I would say. Your getting an error beep but I dont know for what reason.When arming the alarm I only get a single beep and thats it.
Wouldnt say you should be using suite's, just stick to having zones in areas and stay away from arm suite's.I've updated the Suite Arm Modes
Personally i would default your panel completely and start again, once you connect your zones up you only need change a couple of things to get up and running.
Change exit mode to 'timed set' (areas... arming modes)
Switch off your unused zones (so 3-8? all 'not used')
Turn off the 'locked by timer' options for the master code (setup users...User 01 Master....)
All I can think of right now but probably other minor stuff too.
