Texecom Premier 48 bringing up to date?
15 Nov 2010
I have a Texecom Premier 48 alarm system that was fitted in 2011. The keypad shows firmware v8.13.
It has the dialler (don't think it works), 8 pir sensors, 6 surface mounted door sensors, 1 garage door contact , 2 keypads (hallway and garage). All hard wired.
Is it possible to update this system to a newer one to enable alerting over wifi or similar or will I have to replace the main unit and keypads (retaining the sensors)?
I'll look to get an expert in but wanted to know my options before I do.
Thanks in advance.
Echo that of the above, if your thinking of extending it then a kit 5 does have wireless devices etc if you want to go that way.
Also look at for kits including smart coms as well as buying parts separately as it can make a difference.
Thanks for replying, good to know I can utilise some of the kit I currently have.
Can I keep my existing keypads? They're brushed steel type so hoping I can
