Texecom Premier Elite 24 (Metal) Wiring Help
thanks, Just trying to find the backup option for the panel. Found the user account data backup and done that.
How do you switch off the alarm after the tamper is set off?
A tamper is a 24 hour circuit, you have to fix the tamper or get the panel to ignore them.
You can silence the alarm by typing in your code, but if you reset the panel, the next time the tamper registers the panel will generate a tamper alarm.
I just will have to set off the tamper to put the cover on as I used the screw to keep it off!
Where can I find panel data backup option before I play too much?
put the panel in engineering, put the lid back on, screw it up come out of engineering.
back up, just save and the next you you open it is there, or click on Accounts, back up account data follow on screen instructions
if you save the account it saves the settings, if you change the account without saving, the old values are still there.
