I have a Texecom Premier Elite 64-W with wireless Ricochet sensors which I've been working on installing. There are a few things that I'm not sure about in terms of the set-up and which I hope the more experienced amongst you might be good enough to help me with please. Thank you.
1. When I carried out a walk through test, then the PIR sensors only activated when I tapped them, they didn't activate when I was in the room. Any ideas what might be going on and how I resolve this please?
2. Would I be best to erase the default Master and Engineer codes? I ask because wouldn't leaving them allow anyone who knows these 2 easily obtainable codes to access the system from the keypad?
3. What do the ‘Entry 1 Delay Time’, 'Entry 2 delay Time' and 'Second Entry Time' settings in the Areas menu in Wintex relate to please?
4. Is there a consensus view as to whether the Area arming mode for the whole house (small terraced house) is best set to 'entry/exit' or 'timed'?
5. Is installing the bell as simple as learning it to the system and mounting it after I've done this?
