- Joined
- 16 Jun 2018
- Messages
- 3
- Reaction score
- 0
- Country
I'm in the process of trying to setup a Texecom premier elite 64W.
When initially setting it up, I managed to get all the wireless sensors etc paired and working. But I was having difficulty with timer not working correctly when arming the system:
Areas set to timed entry with 30 seconds, but the system was arming within around 15 seconds.
So I decided to reset to factory settings by removing mains and battery power from the panel, holding down the 'defaults' button, and reconnecting the battery and mains power.
With the wireless keypad connected to the engineer port on the panel, I could see NVM erase counted down, and the panel appeared to go back to defaults.
After entering the default engineer code, I am getting the prompts to select language etc, and then chose whether to 'default wireless', I am selecting yes, then when prompted to 'learn ricochet', choosing yes for this also.
The problem I am having is when clicking on yes for learning any of the ricochet zones, the panel is giving a single beep and not doing anything.
Also zones 1 to 8 are still enabled, I am sure these automatically disabled themselves when i enabled wireless on the first setup.
Any ideas? I have reseting the panel a couple of time, as well as erasing NVM within the engineers menu.
Interestingly the wireless keypad 'pairs' straight away even when the panel isnt in ricochet leaning mode.
