Texecom premier elite arming message
10 Nov 2013
West Midlands
Hi
Got an issue where when I arm my system, full arm or part/evening arm, it works but doesn’t display this on the lcd. It just shows the date and time. Not sure how I’ve lost this but only noticed recently, does anyone know how I can get this back on pls? Thanks
When you say lost???
The arming displays normally when in progress.
The arming status should not normally be displayed on the keep pad ie armed it part armed.
To change this you have either changed the area the keypad displays.
Or changed some of the grades from 2 to 3 in global options.
If you haven’t been changing settings/ upgrading panel firmware then at a loss as to why it would have changed.
I had lost a lot of settings about a month ago so had to reconfigure a lot of it. So arming displays when in progress but when armed we used to see the message like “full arm” or “evening arm” but handy when you know it need to be disarmed?
Will see if I can find the area settings, thanks.
The grading are in global options system config.
EN50131, depending on panel firmware version will determine the exact number in the list of options but its in 30s +
It has been covered here and on the Texecom forum several times.
Knowing a little of what's been done can help speed up the rectification.
Thanks got it working now.
34 en50131 is disabled
53 pd6662 is off
Thanks everyone for your help again.
