“When you have eliminated the impossible, whatever else remains, however improbable, must be the truth”
Sounds like your back up battery in the control panel needs replacing if it's only giving you 45 minutes standby time.
Yes,would a low battery cause it to go into alarm when the mains supply is disconnected
If you measure the voltage on the battery when the mains supply is still connected you will get the voltage of the charging circuit and not the voltage that the battery will supply when the mains is not available.
The capacity of the battery will decline with age and can be estimated by the rate of decline of voltage when the battery is supplying power to the panel when there is no mains supply.
A healthy battery.
Voltage is NO indication that there is any capacity available, in the same way
that fumes smelt in your car fuel tank is NO indication that petrol exists!
Just to clarify, you say that you have disconnected all 4 wires from the
PIR are you on a Global Tamper (cables back to TAMP connections on panel) or EOL Tamper.
If you have a Global Tamper installation then you should have at least 6 wires to the PIR (pos and neg from AUX, 1 pair to Zone 5 and one pair as Tamper)
