A few points:
You are allowed to spur only once off any socket on a ring main.
If you so wish you could put in as many Junction boxes on a ring main as you liked and spurred off each of those junction boxes once each. (Not adviseable but technically nothing wrong with it.
If you Connect a Switched Fused Spur into the ring you can add as many sockets on the outgoing (load) side of the spur like, as a radial. Though when you do this, the radial can only pull as much as the fuse in the spur will allow (ex. 13A)
