Why put up a link with so many flaws in its contents?www.worldarchitecturenews.com/index.php?fuseaction=wanappin.commentview&comment_id=158
Lets start with some basics:
Wrong. WTC7 also had structural damage, as was seen in photos. I should add that it wasn't the only building to collapse on that day due to the two towers collapsing.NIST claims that the Twin Towers collapsed due to the plane impacts and fire, and that WTC 7 collapsed due to fire alone.
So structural damage by large airliners doesn't matter?However, note that the Twin Towers survived the plane impacts and the jet fuel burned off in the first 10 minutes. Beyond that, all we have are not very large office fires.
And how many of those have suffered major structural damage due to airliner impact as well as major fire? When a building collapses, whether its because of fire or explosives, it is going to fall quickly, as gravity does the same job.Over 100 steel framed buildings have suffered major fires, many much worse, yet none have collapsed. All three buildings on 9/11 fell through what should have been the path of greatest resistance...
Controlled demolition using explosives only take out specific supports (other explsoives are sometimes used to control the direction during collapse) and let gravity do the rest, so a building collapsing due to fire will look similar as it collapses, as it will only give way when enough structural integrety has been removed. BTW, the tallest building demolished with explosves was 439 feet and 25-story.
This is laughable. Not only do you have multiple floors intact falling onto the building below (enough to destroy just about any building), but the bracing at the top of the twin towers added even more weight to them. Countless experts have stated that once the collapse started, it could not have stopped.Furthermore, a small falling top section would destroy itself before it could destroy a larger, stronger, undamaged lower section of the building. The impossible collapse is a smoking gun.
The shock loading would have been far too much, as any demolition expert would tell you. Which is why they tend to use gravity to do most of the work in many demolitions.
The temperatures of the fires present a problem for NIST's claim that fire alone was involved. The melting point of steel is about 2800° F. According to NIST's own documents, hydrocarbon fires (e.g., jet fuel and office furnishings) generate temperatures only up to about 2,000° F under ideal conditions. NIST recognizes these fires could not melt steel, so they had to postulate elaborate mechanisms that might trigger collapse due to weakened columns and sagging girders.
More nonesense.
"Elaborate mechanisms"? Even on the day, many of us knew that the steel would not have melted, as all the fires had to do was weaken the steel on an already weakened structure.
There was molten aluminium pouring from the fire areas onto the sidewalk, but there was also UPS systems in those areas, which could have created all sorts of fire/explosions/sparks/misc effects.A video of the South Tower shows molten metal pouring out, glowing a radiant orange-yellow. Some have claimed this is molten aluminum, which melts at a lower temperature, but molten aluminum would be silvery in these conditions. This is molten iron or steel.
I could go on but you get the idea.
These people use half truths, strawman arguments, misrepresentation, and when all else fails... lies, to peddle their theories. Much of it is driven by ego of course. To find something that the mainstream has not. But they fail the most basic scientific methods as they cherry pick evidence to fit the theories they wish to present.
They also fail to explain how not a single person who got out (this includes people who were near the impact zone), never mentioned a single incidence of people working on cutting beams or planting explosives in any way either in the months prior to the attack, or on the day. Given that any consiracy theory can be exposed with one loose tongue, this seems erm, strange. And shows a complete lack of understanding how the world works.
In the end they show huge disrespect to the victims and their families, by continuing with such dishonesty.
