- Joined
- 31 Aug 2005
- Messages
- 4,202
- Reaction score
- 399
- Country
Ok i do like a bit of aviation well the tech side and crash investigations.
Anyway have you seen now there are so many 737max's they're parking them in the Boeing staff carparks
Its a bit of a Brexit conundroum to fix them too, if you haven't read too much, the crux is their inherent aero dynamic instability. The answer was MCAS (an anti stall feature due to the position of the engines and aero profile caused the aircraft to potentially nose up without warning and stall.) And MCAS prevents this by activating a nose down routine to prevent stall, all well n good until a simple sensor fails and the plane thinks it is stalling and instead nosedives into the ground killing everyone of course hence the grounding of these jets.
Now.. the simple solution would be to disable the MCAS system or make it easy to disable but then it makes the plane unsafe i refer you back to the aero design issues.
Will be fascinating (well for some anyway) how Boeing get themselves out of this mess.
Read more here
https://bit.ly/2KDHpcH
Read more here
