Ok, this one is driving me nuts. I live in an old Victorian property, with an original slate roof. The roof is in fair condition, and is dry other than a very small section (about 30cm x 40cm) at the very top/apex of the roof on one side. This section gets wet (varying degrees depending on type of rain). This has clearly been an issue since before we bought the place as you can see where they previous owners have replastered after water damage.
I have had a roofing company up there who removed a tv cable that someone had run from the aerial under a slate and into the loft for a tv, which they thought might be tracking the water. Sadly, this has only made it worse, and the wood now gets very wet, instead of slightly wet.
They have been up twice, and have stated that they cannot see any bad flashing or slates. What confuses me is this problem starts at the very top of the roof (ie where the 2 sloping sides meet at the top, one side is wet from the very top) so to me it suggests the flashing or very top row of slate is duff. The roofing company claim that if they can't see anything on their next visit up (hopefully today or tomorrow) we'll either need to get someone else to look at it, or get them to strip down that section and relay it to make sure it is sound.
Thoughts on this? First of all, if the wet starts at the very top of the roof, surely the problem has to be at the top yes? Gravity would pull any water getting in down and it would present itself as damp patches or drips coming through cracks in the wood yes? Even if the water was wind driven, the problem would still have to be close to the very top I would have thought.
So if they can't find the problem and have to strip that area back, based on the sizes I'm suggesting, roughly, are we talking £500 or £5000?
Thanks all.
Thanks all.
