Hi All
My girlfriend's house had the meter man round last week to replace the meter (funny that!).
Anyway, he commented on my install of the British Gas energy meter (the little box with a clip-on sensor). I'd just shoved it on any old tail (neutral I think) because I'm assuming what goes in must come out and the reading won't be affected by voltage.
The Meter Man has subsequently moved it to the 'correct' tail, the line wire after the meter. Is he right that this will produce a more accurate reading?
Also, I noticed he's labelled the cut-out with 'fused at 60A'. Do you think he's done this for clarity or do you think he has changed the fuse to reflect the main switch on the old wylex (was originally unlabelled, 100A fuseholder).
Thanks.
Thanks.
