I think the fuse ratings specified in Table 2 are fine in the context of the primary purpose of that Table - i.e. to specify the test conditions for the flexing and cord grip tests, which use a test current greater than the CCC of the cable.It seems quite clear - to me at least - that table 2 fuse ratings are a complete balls up using the 3A and 13A fuse preferences as a baseline to work from.
As BAS has identified, the problem is that they have also referred to Table 2 in the context of specifying the required marking of non-rewirable plugs. However, as you will have seen, BAS and I have different views about the interpretation of what that is saying.
Kind Regards, John
