The old Rads warming up when HW is on (and CH is off) issue
And no matter how you try and word it it is NOT a divertor its A PUMP pure and simple.
At no time have did I claim that the SMC Twin Pump system (that this OP appears to have) is a divertor, but you seem to prefer to believe that I did.
Just consider yourself educated on this matter you may come up against in the future and you will not look stupid infront of a customer saying your divertor is bust
By all means dance around in glee at knowing something that I didn't, but you seem hell bent on believing that I said the pump was a divertor, when I clearly I said it looked like a divertor (because it had three pipe connections) in order to identify it to the OP. It was certainly a clumsy description, but given that I asked what it was, you merely have to use a tiny amount of imagination to see what I was driving at.
Returning to your point about the Grundfos pump plan, which you claim is the same as the SMC Twin Pump configuration, you are completely and utterly wrong. The only similarity is that there are two pumps.
I have no problem with not knowing something, whether in front of a customer or not, so your weak jibes are falling on stony ground.
The whole nub of problem solving is analysis, not knowledge. If you applied more of the former then you'd understand my point about the parallel and series topologies. However, I realise that you might be pretending to misunderstand. Whichever one of those is true, I can't work out which is the more pathetic.
There was no need to explain to the OP as the problem was not either of the pumps . And it was pointed out to the OP that what they affectively had was a fully pumped system . But with a non return (anti gravity ) valve
very entertaining :LOL:
Pray tell softas seeing as you now think tou know what your talking about what is the differnce between a grunfoss pump plan and a smc system.
And what is the operation of how both systems work so that they don`t require motorised valves to have a fully pumped system
