Thermal store expansion vessel on incoming cold is it reqd?
G
Goldspoon
I have a situation with a leak (weep) on the small 2L expansion vessel on a vented thermal store. The vessel is on the incoming cold side (i.e. before the mains pressure cold enters the coil for indirect warming.
Now I have fitted a number of thermal stores before and have seen stores with and without this expansion vessel. I understand that the vessel is there because the water in the coil heats upo and therefore expands.
As some stores have this and some do not - can I just remove it rather than replacing?
Presumably any expansion would just "push back against the incoming mains pressure?
That looks like a trade enquiry!
It depends upon the volume of the dhw coil. If it less than, I think, 15 litres, you do not need any dhw expansion. If your main stop tap has a completely loose jumper, it can act as a non-return valve, and expansion could be blocked.
They act as an expansion and shock arrester. If there is a meter fitted then you will have no expansion down the main.
If it's a kingspan cylinder then I would re-fit a 2l vessel.
