I've got a problem with a thermal storage set up
basically the system is a thermal store heated by a gas boiler also running the central heating. The thermal store is fitted with a mains fed heat exchanger coil which on exiting the thermal store goes through a mixing valve to a preset temperature of about 50°C
The boiler is heating the thermal store to 80°C and shutting off, but when you open the hot tap the water starts coming out fairly fast and hot but after a sink full it slows down to a trickle and goes cold.
The temp gauge on the thermal store does drop to about 76°C.
I've tried adjusting the mixing valve and it started leaking, so i've renewed the sealing O ring inside but there still seems to be very little hot water available at the taps.
The system would happily fill a bath and do a sink full of washing up on a single heating of the thermal store when it was installed about 4 years ago.
Anyone have any idea. Is it worth changing the mixing valve, do these often go and limit the flow?
The thermal store is made my a company called McDonald Engineers
http://www.mcdonald-engineers.com/thermflow.html
