Hi, I have a Glow Worm Spasce Saver 50 MK2. I had a problem a few weeks ago with the pilot light (not big enough to heat the tip of the sensor) and found the solution on this forum (cleaning out the pilot light jet). Up untill yesterday it worked fine and the pilot is still very strong.
The boiler has started cutting out after a short time and 'clicks' as it did when the pilot was to low.
Any ideas ???
Will I still be able to get hold of parts ie;
Pilot light sensor
Thermocouple that runs from cast water jacket in top of boiler to min/max/off switch
how often should a system be drained (Lancashire/Yorkshire border)
Cheers.
Any ideas ???
Pilot light sensor
Cheers.
